New Featurescript: Captive Nut
Captive nut makes it easy to add screw/nut joints to parts.
→ Here's a link to a video tour of the feature.
→ Go here to add the feature.
Below is an illustration of the three main insertion styles that can be achieved with the feature. Use it and let me know what you think!
I'm working on a fix right now, and the features will be back. We switched to Onshape Enterprise. A side effect I didn't realize we'd have is that Enterprise doesn't allow public documents so they all disappeared.
I don't have an Enterprise account at the moment, but is it not possible to allow public documents in Enterprise? It seems like there is an option to go the other way around (i.e. whether or not users can access public documents and use them internally).
You have to duplicate the document for it to work? I had tried just transferring them to a personal account, but it didn't seem to work. I'd love for everyone to not have to add the features to their toolbar again. Do you think they would?
So, you should transfer the original documents to "your account" (outside the Enterprise), not "a" personal account.
I just found this featurescript. I've been using Nut Pocket JR but I like that yours is more flexible and includes ANSI hardware.
I'm checking out your beta but I think there may be a bug in the Nut Spec featurescript. When I change the screw size, it doesn't seem to update the dimensions at the bottom of the dialog. I still have to enter those manually. I saw that you have the Captive Nut Table in the feature studio with all of the dimensions. I checked a few and they look correct in the table.
When I don't use the nut spec but just define the nut within the captive nut feature, it seems to work just fine. But I like the concept of the nut spec because I'm often using the same nut hardware in a 3d print in a bunch of different areas, and it's nice to be able to just define it once.
I'd offer to help debug but I'm pretty green when it comes to featurescript code.
huh, it sure doesn't. I'll look into it when I have time. I have a hunch I know what it is and it's not too hard.
It should be fixed with the newest update 👍🏼
Thanks! I was a bit confused because I thought you were updating the Beta, not your main release haha.
I do think I found another bug though - when selecting a 1/4, 5/16, or 3/8 size nut, the nut spec dialog displays the "Fit" dropdown twice. It doesn't seem to happen for any other ANSI size, but I haven't checked the ISO ones.
Thanks for bug testing! I fixed it. I also checked the ISO table and didn't see any other issues. I must have duplicated some entries trying to do some find/replace magic to make big edits to the lookup table for the nuts.
I would find this super useful but not quite the "hole" function that you had referenced and removed. It really is about getting a better adherence for the metal part when you start to print over the top. I have tried adhesives and the like and none quite get the job done and doing what is described in the video is a little bit tough by hand each time. It feels like a single layer rectangle that you can still place a hole using the native tools. Just a suggestion. Again, love the work, it is really a time saver.
I didn't watch the video just now (though I have in the past a while ago). Based on the thumbnail it looks like it's already been scripted by @imants_smidchens. Check out his Bridge Counterbore. I use it when I need to. Works great! However, if the nut is inserted into the part it might already provide the support the plastic needs, and make this step unnecessary.
I tried the Bridge Counterbore but it doesn't actually work (that I can make happen) when you use yours to embed the nut inside of an object. I then cannot get the Counterbore to allow the selection of the face of the captured nut. Any thoughts?
