Animated Assembly Documentation
elizabeth_giovanardi
Member Posts: 21 EDU
I am hoping to create an animated assembly video to show how an assembly will go together, such as seen in this YouTube video https://youtu.be/1dZzA1jBHTA Is there documentation in the Learning Center to show how to do this? I assume it is more than simply setting artificial limits on the motion and then animating this? Thanks!
NeilCooke
Moderator, Onshape Employees Posts: 5,983
Sign up to Cadasio in the App Store.Senior Director, Technical Services, EMEA1
So there are a few things you could do.
Animate each part one at a time and edit the mouse clicks out of the video.
Or You can make a bunch of slider mates then connect the slider mates with linear relations and varying ratios.
Then the whole thing will explode smoothly but all at once.
Or you can do the rubiks animation trick...
One of these days I will find time to make a short video explaining the basics of it
