Phantom Discontinuity At Mirrored Surface Seam
matthew_stacy
Member Posts: 489 PRO
Why are faces generally split at the seam when a surface is mirrored?
In this example (https://cad.onshape.com/documents/51b9043cee7e3dbb60c1192c/w/31a742765743fe1fd962a776/e/7ad5ec31da1120d731ab044c) a lofted surface is shaped with guide curves. In one Part Studio the guide curves are sketched "full-span", symmetric about the front plane. The result is a single smooth contiguous surface. In a second Part Studio only half of each guide curve is sketched. When this surface is mirrored there is a visible seam at the plane of symmetry. Turning on curvature visualization indicates that the underlying geometry appears to be identical in both Part Studios, but one has a seam.
Unless I am missing something these "half-span" guide curves are identical to their full-span brethren, with exactly the same tangency and curvature constraints where they intersect the plane of symmetry. So why is the mirrored face split? And is there a way to merge them into a seamless whole?
NeilCooke
Moderator, Onshape Employees Posts: 5,987
@matthew_stacy - extruded and revolved surfaces are analytical geometry i.e. their shape can be described with simple math. A surface created by splines is a whole different ball game and @Evan_Reese is right - it is not possible (or not easy at least) for Parasolid to recreate the math for the whole mirrored surface with perfect accuracy.Senior Director, Technical Services, EMEA0 -
EvanReese
Member, Mentor Posts: 2,865 PRO
Interesting point, Neil. I hadn't fully thought about what's happening when it merges those simpler surfaces. Is it making a new surface and replacing the old one (including IDs and all that)?
Either way, I don't personally think I'd get a lot of value out of making symmetrical surfaces with no seam any more than I would by removing tangent edges of fillets. The only time I would want to do something like that would be to have a clean single surface to drive an Attractor Pattern feature with. To map a pattern across multiple surfaces I may have to spend a decent amount of time making that clean base surface that's similar enough to the parts I want to texture.0
In your second example, you made a surface that's half the size and it's UV curves look like this. see how the UVs are all smushed together?
To merge them into a whole, you'd have to recreate a similar (but not mathematically identical) surface to replace them with. I actually don't recommend this and prefer to have a split line where I want true symmetry, because it is possible for the part to look symmetrical, but not actually be symmetrical, which can cause other issues down the line. The split line is a clue that it's perfectly symmetrical.
