In Part/assembly properties allow part number to be a formula
ryan_mcgoldrick
Member Posts: 71 ✭✭✭
Example,
Our part numbers are made from
Project number- Item Number - Version Number - Release Number
In solidworks we could use a formula to automatically generate the Part number
something like #/= Project number - Version Number - Release Number
- = Dash not a minus.
I've done something like this before so it renumbered my entire project.
Basically for the fields here you jut make variables
Here is some base code to get you started:
FeatureScript 1403; import(path : "onshape/std/geometry.fs", version : "1403.0"); annotation { "Feature Type Name" : "Part Propertiesx", "Feature Name Template" : "#Name" } export const PartProperties = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Part", "Filter" : EntityType.BODY && BodyType.SOLID && AllowFlattenedGeometry.YES, "MaxNumberOfPicks" : 1 } definition.entities is Query; annotation { "Name" : "Name" } isAnything(definition.name); annotation { "Name" : "Name Includes Part Number", "Default" : true } definition.NameWithPartNumber is boolean; annotation { "Name" : "Job Number" } isInteger(definition.JobNumber, POSITIVE_COUNT_BOUNDS); annotation { "Name" : "Unit Number" } isInteger(definition.UnitNumber, POSITIVE_COUNT_BOUNDS); annotation { "Name" : "Detail Number" } isInteger(definition.DetailNumber, POSITIVE_COUNT_BOUNDS); annotation { "Name" : "Is Sub Detail", "Default" : false } definition.isSubDetail is boolean; if (definition.isSubDetail) { annotation { "Name" : "Sub Detail Number" } isInteger(definition.SubDetailNumber, POSITIVE_COUNT_BOUNDS); } } { const part = evaluateQuery(context, definition.entities); const JobNumber = toString(definition.JobNumber); /* add leading zeros Detail number */ var x = definition.DetailNumber; if (x < 10) { x = "00" ~ toString(x); } else if (x < 100) { x = "0" ~ toString(x); } else { x = "" ~ toString(x); } const DetailNumber = x; /* add leading zeros Unit Number */ x = definition.UnitNumber; if (x < 10) /* add leading zeros */ { x = "00" ~ toString(x); } else if (x < 100) { x = "0" ~ toString(x); } else { x = "" ~ toString(x); } const UnitNumber = x; /* Format Part Number */ var PartNumber = definition.JobNumber ~ "-" ~ UnitNumber ~ "-" ~ DetailNumber; /* Add .number for sub details */ PartNumber ~= definition.isSubDetail ? "." ~ definition.SubDetailNumber : ""; /* Rename part to include part number if wanted */ const Name = definition.NameWithPartNumber ? PartNumber ~ " - " ~ definition.name : definition.name; /* Make Feature on tree match part name */ setFeatureComputedParameter(context, id, { "name" : "Name", "value" : Name }); /* Save properties to part */ if (part == []) throw regenError(ErrorStringEnum.CANNOT_RESOLVE_ENTITIES, ["entities"]); const Part = part[0]; setProperty(context, { "entities" : Part, "propertyType" : PropertyType.PART_NUMBER, "value" : PartNumber }); setProperty(context, { "entities" : Part, "propertyType" : PropertyType.NAME, "value" : Name }); setProperty(context, { "entities" : Part, "propertyType" : PropertyType.DESCRIPTION, "value" : definition.name }); });
