Global configuration in the document. My workaround. How to make it works?
I spent a few hours of digging in the forums and manuals. I know that Onshape still hasn't a normal way to make global configuration at least in the bounds of the document. Ok.
I tried to invent the crutch. And I almost made it, I think. But it doesn't work
Here is the demo document - https://cad.onshape.com/documents/057ed93cbbf4ea11c405e9ed/w/4b232b5d232857ea4f611124/e/06d16d4e725713c329d7b24a.
Tab "configuration" - it should be a global config of the document. No sketches there, only configurations.
Tab "fs.globals" is a crutch itself. It serves as a bridge between Configuration and other PartStudios. Mapping of configuration to variables.
Tab "demo" - demo part studio.
At the first glance it works. I specified some values in the config and used their mapped variables in the demo sketch. As you can see the rectangle in size of the config values.
But when I changing the configuration it doesn't apples anymore to my sketch. Even if I'll draw a new objects, they still "see" the old config values mapped to the variables.
So, how to update FS variables when configuration changed?
My intention is to share configuration, not the variables in the PartStudio. It's a big difference from the user point of view.
