Imported assy's component order comes in backwards on tree
Hello, I'm in the process of evaluating changing my company from Creo to Onshape. I exported the top level assy from creo as a STEP (parasolid had errors), and imported into Onshape. Everything works as expected, except the order of the components (parts) are backwards. Below see my screenshot of Creo (correct), Onshape (incorrect), and Fusion360 (correct). Does anyone know how to fix this without manually rearranging things? This screenshot only shows 5 sub-assy's, but inside each sub, are many, many, more subs and individual components. They are all backwards.
Also while here, is there a way to add columns to the onshape tree like you can in Creo?
I searched for both questions and didn't find anything. I also did a lot of the tutorials over the past two weeks and didn't see anything.
Thank you!
NeilCooke Moderator, Onshape Employees Posts: 5,847
I am not sure why they are coming in backwards, can't say I ever noticed. Assembly order is not important, but if it is a concern the only option here would be to manually reorder. And no, there is no option to add columns.Senior Director, Technical Services, EMEA0
What do you mean "assembly order is not important"? To me this is an essential tool. I've used the assembly feature tree in Pro/E and Solidworks for years to show the order of the physical assembly. This is not a random thing - it carries a lot of meaning and information.
Assembly order is important, especially if you want to use the BOM...
