it seems when i try to select the face of main sketch it is selecting around the inside diameter of the wheel as well as going down the spoke to the hub. for whatever reason i cannot select just the inside diameter of the sketch as per what the directions are saying to.
i hope that makes sense
You are correct that we have the wrong closed caption file there. We will fix this.
I don't want to email all the files to every student, so I was hoping there would be links to the files. I looked at the Relevant Links and Resources.docx, but it was not helpful.
-The links for the videos do not match the titles. For example, 1.1.3 – Design Intent https://www.onshape.com/videos/tutorial-design-intent
takes you to a video about configurations.
-The links to Exercises take you to the Onshape document templates, but do not show the pdfs to walk you through the exercises.
-There is no link to the quizzes
I could copy everything to my Google Drive and create links to all the files, but it seems like there should be a better way.
Could you please give me your thoughts?
Thanks,
Steve
The instructor kit was taken down because it was severely outdated to the point where it was unhelpful since the UI and functionally in Onshape has changed so much from the screenshots and videos in the kit.
What we did was invest in creating four new courses for an introduction to CAD level in an Introduction to CAD pathway that can be used in the classroom, by students and teachers in our Learning Center. We are also investing a lot of effort in creating more advanced part geometry courses like Understanding Curves and Advanced Part Design, and there will be more to come in that area!
I know its not exactly an instructor kit with instructor-only resources, but do know all the self-paced courses, videos, and technical briefings in the Learning Center are made available to EDU subscriptions for free, (you just need to be signed in to Onshape to access). I would encourage you to use these resources for you and your students. They are made keeping both students and professionals in mind.
The academic team is working on a number of new materials to help instructors in K12 and in the University space easily get started with teaching Onshape and will be rolling those out of the next few months. We've created a one pager pdf here: https://apps.ptc.com/schools/OnshapeEducationGettingStarted.pdf that helps to outline the resources that are available today. We'll continue to update that as more resources are released!
I am stuck in the learning center with the new Surface Modeling Learning Pathways.
On the Helmet exercice, I have issue with the Shell feature. I cannot remove the faceshield:
Can someone help me? I do not see where I have a difference between the tutorial and my model.
https://cad.onshape.com/documents/ee4b406d8335e36ac931b8ec/w/d45ee19ef7ec5f0bdf8556c7/e/b430d9d75d673442426a5cb3
Thanks
EDIT: I found the issue, I made a mistake of spline lenght. But still does not quite understand why the shell feature behave like this
Hi Katie, I noticed that there is a problem in the "OnScale Solve Simulation Fundamentals"
In the bike frame excercise, the units seem wrong. The bike frame is only 0.080m long. Which is pretty small:
The problem seems to be in the Onshape document. There the bike frame is also too small.
I can't find the Quality slider for the mesh in OnScale. Could it be that they changed their UI?
Thanks for your help, that's pretty funny
For the mesh, Use the "Refine" button, as the slider was removed from their latest release.
You can also reference this article that I found as well: https://onscale.com/blog/mesh_in-_no_time
Toward the bottom is a section on refining the mesh using that button.
frames fundamentals, exercise 5 custom profiles.
the course is telling me to add "#" to a dimension to bring a pop up to make it a variable dimension. adding "#" gives me the message enter a valid expression, the box turns red and no pop up appears.
In Sketch1, my attempt shows the corners of Face of Extract 1 in red.
which doesn't happen on the solution.
When I move on to the Rib1, the solution show the profile as Edge of Sketch 2 but on mine, it shows as Edges of Sketch 2 and when I get to Rib 2, my diagram shows the underside as solid whereas the solution shows it as hollow.
I am totally stuck and hoping that someone can spot where I've gone wrong.
Link to my document: https://cad.onshape.com/documents/6c34be42b9d991c95456e30e/w/a2979169fa926a983b8710a6/e/bc34327902bd583ce07784c9?renderMode=0&uiState=66350ab0ec07681110fba3f3
