Forcing point-to-point dimension to be aligned rather than horizontal/vertical
alan_buddenalan_budden Member Posts: 7 ✭✭
I'm trying to create a drawing of an object I've modelled.  One of the key dimensions is the distance between two points along the angle that joins them.  I can't use the dimensions of the line joining them as there's a cut-out that splits this line.  If I try to do a point-to-point dimension in the drawing, it wants that dimension to be either the horizontal or vertical distance.  I don't want this, I want the aligned distance.
As a test, I made a very simple model that (I think) shows what I'm trying to do.  Here's a screenshot of the drawing:
What I want it to look like is this (created with an image editor, not onshape!):
Is this possible?  I found this question on this forum, which makes it look easy, but I can't figure out how to make it actually work with my models.
Test model is here: https://cad.onshape.com/documents/4139e053de38affdffc7f670/w/24168f2e4bd934650d5b95d4/e/63356c08b37bf47fb71b3269
