How do you establish a mate between an axis and a plane
Hello everyone!
I want to establish a mate connection so that the shaft below pushes the pin up and down.
Is it possible?
Best regards
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Not if the contact is intermittent (i.e. the shaft must always touch the pin) - the pin can use a pin-slot mate and the pin to shaft connection can use tangent mate.
  • goncalo_torresgoncalo_torres Member Posts: 4 EDU
    Thanks! It is exactly that what I have to do.
