How do you establish a mate between an axis and a plane
goncalo_torres
Member Posts: 4 EDU
Hello everyone!
I want to establish a mate connection so that the shaft below pushes the pin up and down.
Is it possible?
Best regards
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Not if the contact is intermittent (i.e. the shaft must always touch the pin) - the pin can use a pin-slot mate and the pin to shaft connection can use tangent mate.Senior Director, Technical Services, EMEA0
