Why are fastened offsets sign (+/-) a crap shoot?
marten_hutchison
Member Posts: 32 EDU
in General
So irritating. In an Assembly, if I Offset two mated parts i.e. in the Z axis, when I enter a distance value, its a crap shoot whether the direction (+ or -) is right. Invariably its wrong and I have to enter it again. Its an irritating little time suck. What am I missing?
3
The trouble I have is that the orientation of the mate connector can be hard to see clearly in big/complicated models.
Another way to see is that when you change the mate's z-offset to a positive number, it's the first part you selected that moves in Z+ direction relative to it's own Mate Connector .... This can be confusing becuase we conceptually think about the two parts we are mating as moving toward / away from each other. However, I think the movement is ONLY related to the first selected part's Mate Connector axis direction. It's almost as if the offset is really only affecting the first part relative to itself.
great analysis! very helpful
