Sketch from Sheetmetal Pattern
steve_maiettasteve_maietta Member Posts: 54 PRO
edited February 2021 in Product Feedback
Generating a sketch from sheetmetal flat pattern.  So I could easily add tabs, flaps etc.
  Either using the "project" tool or a one click convert would be nice and useful.
Otherwise it's not apparently possible without putting the pattern into an assembly and then generating a sketch from that.  Which works but kinda clunky and ends up giving many doubled sketch entities.
thanks
~Steve
    romeograhamromeograham Member, csevp Posts: 659 PRO
    @steve_maietta Don't forget to vote for your own IR!
    lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002
    @steve_maietta Do you have an example?  You can sketch in the flat today but I just want to make sure the steps in your workflow before I write up an improvement  or suggest a solution.
    @lougallo, My example is a simple box (package design) with the intent of making it from paperboard.  I need "tabs" that get folded under the sides and are glued to seal up the specific edges.  At this point, I have been able to add these as tabs in the original sheet metal part studio.
    I went ahead in the project and was trying to force it on a project that was almost finished. .  It ended up being alot easier to start again and add them in the beginning.  So I do not need this anymore
    BUT - it still seems like a good basic functionality.  One click to turn a sheetmetal pattern into a sketch.  Select the plane, select the origin, boom new sketch disassociated from the orignal pattern.
    Thanks for looking at the request LOU!
    ~Steve
    I still think you might be able to add these into the flat area today but I would need an example.  I will reach out.
    @lougallo
    https://cad.onshape.com/documents/f832c9927ab7e920371aaa66/w/d8333d7d92fedf3d7bf6acb6/e/52b1a5348cc916b24d92b3e9
    Heres a simple box.  I could add tabs on the model using a sketch and the tab tool.  But I think it would be useful to be able to have the pattern "exportable" as a sketch.  Somehow to turn the pattern into a sketch    I realized that I approached the project with the wrong sequence originally, but still this ability may be useful.
    I tried adding in the flat area but I believe interference was happening..  something was keeping them from building successfully..
    ~Steve
