revolve remove command
bradley_horner
Member Posts: 5 ✭
in the self paced classes, there is a coffee cup exercise. I'm trying to use the revolve commend to remove the inside of the cup. it lets me select the axis to revolve around but I can't seem to get it to let me select the area to revolve. when doing the revolve with the new option I didn't have the issue, but when I select the remove option ... Help please.
steve_shubin
Member Posts: 1,118 ✭✭✭✭
bradley_horner said:... and it is this remove revolve that I can't get to work.Here is what @Evan_Reese snd @glen_dewsbury are saying
Your Revolve 1 did not make a part
Your Revolve 1 made a surface
To get a part, you need to change the dashed construction line for the REVOLVE AXIS to a solid line. This will produce an enclosed area (gray) in your sketch, which will allow you to revolve a part instead of a surface
Also - when you do Revolve 2, make sure that Part 1 is selected for the Merge Scope
can you post a link (with link sharing or public doc options) or a screenshot of the sketch you are using to create the revolve feature? Without this its hard to know where you might have went wrong. My guess is your sketch is not closed- meaning your don't have a shaded region in the sketch you are trying to revolve. Another thought is the area you are trying to remove is not intersecting the coffee cup?
guess I'm too new to understand some of the terms, but no I don't think I've got a closed area to revolve, the exercise directions said to do the center axis as a construction line and then the profile of the cup off of that. so effectively there is only the top,bottom,side that close on the center construction line. so I'd not think that is a closed area?
https://cad.onshape.com/documents/98273f88165ecb9be25a1ff5/w/7ce04cd8b68ca9cb9fbcbbf0/e/740f906ed282d25f52a947ca
