Construction line used in creation of a Revolved Surface? I assumed construction lines "ignored".
 christopher_owens
                    Member Posts: 235 ✭✭
christopher_owens
                    I stumbled across this creating a revolved surface. In Sketch 1 is a construction line that is to be used as the axis of revolution. When doing a surface it fails saying surface intersects itself. But click on Solid and it creates the solid! Something to watch out for?? I selected the entire sketch by picking on it in the Feature list. I assumed any construction line would be "ignored".
             lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 We have marked this as a bug and are fixing it.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6 We have marked this as a bug and are fixing it.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6
I tend to use construction lines allot less in Onshape than SW, as it seems to be able to handle most things with out having to have construction lines. However still a good tool in the arsenal.
