Can one configuration option be used to show/hide other configurations options?
I am trying to automate creation of solids, sections & developments for students for a subject they have.
I want them to be able to select type of solid like prism, pyramid, cylinder & cone. Based on the solid selected I want the additional configurations like height, base edge length etc to be made visible in case of 1st two & circle radius in case of the last two.
here's the file I am trying to achieve this with.
https://cad.onshape.com/documents/b2959c4eef3207fb91c5330f/w/2f25a797f3f1cd233eca1f6f/e/2e5ad22b67135e91b6d69106
POSSIBLE?
    Not with configurations but you could do it with FeatureScript
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 560 ✭✭✭
    @Evan_Reese
    I am with you, this is on top of my list for improvements
  • shrekantshrekant Member Posts: 16 EDU
    Thanks for taking time to comment.
    Will keep my fingers crossed to get this in future updates.
    Can you please guide me to the page which would help me understand how to achieve it?
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    This would be a great improvement.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 162 PRO
    This is an IR that we would incorporate into every one of our configurations if implemented.
    chadstoltzfus@premiercb.com
