What does "Some of the geometry intersects itself or is degenerate" mean
I am new to OnShape. I have a .dwg file exported from Illustrator that OnShape is having trouble with. Part of the file works and part doesn't. I've been trying different things but nothing helps. Even if I bring it in as two different files, the one that works is good but the one that doesn't gives me the above error. I've checked for grouping, non-continuous lines, fill, non fill, etc., etc., etc.
Attached is the .ai file. The "r" in the logo works. The "m" gives me the error above.
Here is the test:
https://cad.onshape.com/documents/cbbbd6682a0090b36f9c49ba/w/dd767eed9de6522824d3286a/e/6c79d14d242f6b7e8271a0f7
Let me know if anyone if anyone has an idea
https://cad.onshape.com/documents/4fa113c6594cd037bfa214da/v/e5f9020158b188b1ec33530d/e/4eb9378eccc7b7a0261b6f14
Also I've found the issue, it's in this area:
If you box select like this and delete it gets rid of the error:
