Parts studios & shared dimensions
CaptainBisquick
OS Professional Posts: 33 ✭✭
Am I supposed to build all my parts in one studio, or each part in a separate studio? It seems like it will be more difficult to model parts that fit together if I can't view the complimentary part while designing the new part. And what if I want to use the complimentary part for external reference?
I looked for tutorials on using parts studios, but I don't see any covering this part of the workflow. I've seen the one that shows how assemblies work, but that doesn't seem to address my questions.
traveler_hauptman
Member, OS Professional, Mentor, Developers Posts: 419 PRO
Generally you can treat a studio like a top-down assembly. All related parts with common interfaces, shared dimensions, related features, all go in the same studio.
Onshape is in progress so some of the capabilities needed to make this approach work well are not yet implemented. External references is the main missing capability. So we don't yet have relationships between part studios (neither same document nor external documents). But it's coming.
5
But the beauty of Ons is that you can make how ever you wan't - if you like you can create each part individually like traditional cad - or create multi-part design - you make the decision, not software.
1. You can copy the sketch and paste in required plane.
2. you can project one sketch to other parallel plane using "Use" command.
Here the one discussion which is similar to your problem.
https://forum.onshape.com/discussion/comment/9252/#Comment_9252
https://www.onshape.com/videos/essentials-multipart
It's a revelation (and I don't say that lightly)
