High School teacher looking for guidance
I am electrical eng by training but have started teaching an intro to eng high school class. Interested in using onShape to introduce students to using CAD and to create some basic designs that we can later print on our makerbot 3d printer.
Is there an outline or instructors guide for what online courses to use from onShape and in what order to help give a basic introduction? I am transition to online instruction for my students and this appears to be a good way to introduce cad and 3d design while also introducing a 3d cad tool that is commercially used by many universities and companies.
Thanks an advance for any advice you can offer or links to a syllabus to follow for next week or two.
Regards,
Jim
Regards,
Jim
Dig into the Learning Center! The content we have is designed for students and professionals alike- its not exactly an instructor guide, but courses your students can do. EDU Onshape subscriptions receive access to all of the self-paced content, technical briefings, and videos in the Learning Center for free.
We have an Introduction to CAD pathway that is geared towards students, learning how to model and design in a parametric feature-based system for the first time. I think this would be a great place to begin to design a curriculum using this content. When a student completes the pathway they receive a Completion Certificate after completing the survey- so you can check to see if they have done it.
There is also an Instructor community forum- that is a good place to discuss with other instructors curriculum ideas using Onshape.
I think those are good resources to get started! Let us know how else we can help!
Good luck,
-John
I use the Learning Center Self Paced Tutorials and drawings/parts I find in our textbook to reinforce the software skills. BUT do not start at the top of the list. Here is a basic outline of my curriculum this year (Covid Remote Instruction Friendly).
- Introduction to Parametric Feature-based CAD (I include teacher introduction of Onshape, how to navigate and move within the program).
- Introduction to Sketching
- Teacher supplied 2D Sketching problems (from class textbook), 3-7 parts of varying difficulty.
- Introduction to Part Design
- Teacher supplied 3D parts (from class textbook), 3-7 parts of varying difficulty.
- Part Design Studios Tutorial
- Design problem using the concepts in the previous tutorials.
- Multi-part Studios Tutorial
- Introduction to Assembly Design
- OnShape Assemblies
- Teacher suppled assembly problems
- Introduction to 2D Drawings
- Detail Drawings
- Teacher supplied parts to make drawings from
- Design problems and/or reverse engineering problems.
All parts in the tutorials are turned in to me (Shared) for assessment. I note revisions using the comment tool and by making versions when I grade the part. Then I return them to the students. In addition to grading for part accuracy, I also consider the method (feature build order). All parts must be built in correct orientation, reasonably minimal features, no empty sketches or red features, no undefined sketches (exception: construction lines endpoints). I need incorporate feature re-naming, but I have not done that. All parts must be named with our class naming format that designates class, student (username), part number and part name. My upper level classes use sheet metal, surfacing, but also focus on drawing creation using section views, auxiliary views and conventional drawing practices.I additionally infuse my instruction with CAD skills by introducing the different tutorials and go over best practice for sketching and review tool tips and uses that are not covered in the tutorials.
https://www.youtube.com/channel/UCcqqqH3ocFAgjkt7CUfrNaQ
First year using Onshape because of Chromebooks can't use AutoCAD effectively.
Thank you Onshape for your help through these times. In fact I am adapting Onshape into my curriculum after this year.
I assigned my students the two basic modules in the learning center, then moved on to actual drawing projects.
I found the keychain project doing a Google search. The I stumbled across a Youtuber that had 19 more projects. Big help.
I thought at this point that would be enough to keep them busy until Christmas. Nope. some of the over achievers finished up all 20 projects last week. So now I am introducing them to "Templates". They will go back and make a mechanical drawing of all 20 projects now. Then the next step I am going to is to introduce them to assembly drawings. The next step would be animation or that is the direction I am going. Throughout the whole drawing projects i am having them export as a .stl file and then 3D print there parts. The keychain assignment everyone got to 3d print and take home. I am picking 19 students to 3D print the other projects, to save money.
That should be enough to keep a normal student student busy throughout the school year, I would think. But some of my students I may have to do more research to keep them busy. My thoughts were to introduce to CREO since it is the same company. By the end of the year most of the students should be able to design and make there own parts and then 3d print them. To go another step farther you could have them journal their process using the Engineering by Design Process. This would set them up for further knowledge.
My goal would be for them to be able to use all of this to help be on the Robotics team and be a better competitor.
@jim_reilly I used the Onshape Self-paced courses with my Intro CAD class last spring when our school switched to remote. My students found the tutorials to be straightforward and easy to follow. I assigned 1 or 2 mini lessons for each class (extrude for one day, revolve for another). I would introduce each tool with a few examples of how that tool was useful in part design (How loft makes it easy to design a wing, a vase or a nozzle).
The fact that Onshape works on Chromebooks was huge.
Teams make it very easy to share files, and the comment tool was great for feedback. Really importantly, the design history makes it very hard for students to copy one another's work.
David
