Start of sweep along helix
I have a rectangle in a sketch, and an helix to sweep along.
When the helix has three rotations, it works as I expect:
You can see the sketch, and that the part starts there and goes on following the helix.
If I modify the helix to make four turns, the start position of the part is *above* the sketch:
What is going on? How can I keep in control of the sweep's start position?
Here is the model: https://cad.onshape.com/documents/67fb028a75ce82f860b6a0af/w/67a2efe8ba077c46e15dd6af/e/3523f2ce85349cc194eefe20
steve_shubin Member Posts: 1,113 ✭✭✭✭
@gauthier_östervall
I guess the reasoning is —A profile does not have to be placed at one of the ends of the path. It can be anywhere along a sweep.
Apparently, the program keeps it simple in making the sweep according to the closest part of the profile to the path
1
Principal Technical Services Engineer, Onshape
jjohnson@ptc.com
Weird...
looks like it has to do with what part of the profile is closest to any part of the helix
