Standard Content - Edit Appearance
CAD_Hero_1337
Member Posts: 12 PRO
I am adding in standard content...
6-32 x .25 phillips flat head - stainless steel - black
I want the hardware to be black in the model and not just show up in the BOM indicating it should be black.
Support said that i should right click on the part in the list and choose "edit appearance" but that option is not there. Anyone have any advice?
9
You cannot change the color of standard content at this time. They are versioned parts and we do not have a mechanism for you to change colors of versioned parts. We could, in the future, include it as a company defined property much like standard content part number and description.
Not everyone wants content to be the color it exists as in real life. Some companies want different sizes or types of fasteners to be different colors to easily identify them on an assembly.
We will be adding you to an improvement request.
Having the appearance and also vendor be company defined parameters would make standard content useful for our group too.
Thank you,
Janik
I had that thought before but standard content isn't available for deriving in unfortunately!
The closest alternative is to use a context and "copy in place".
Ugh. I just assumed that standard content worked like any other parts.
I guess this is one more reason that it would be nice to have "semi-custom" or "semi-standard" (?) content which could be customized more than what's currently available.
Ditto to this.
Throwing another vote in to make this happen.
For us hardware finish is pretty critical especially if it's an exposed fastener. The more we can show that in the assembly documents the better. Manufacturing gets confused when a screw that should be black zinc looks silver.
Is there an improvement request for this issue? This blocks me from utilizing the cool functionalities of the standard content.
You may wish to use this fancy fastener creator document instead. Has configurable appearances and all kinds of bolt head options etc.
https://cad.onshape.com/documents/f194954dce2ac8fddc64f30b/w/464fd0c663f79bdc00f3b0ed/e/f11db521de936cff5d093c19
Bumping this again. The standard content feature is so very useful, but the appearance of fasteners is important to my models. Would love the option to edit appearance!
I'd like to see this improvement too
Another vote to see this improvement.
We use different material o-rings in different locations and it is critical that they are the right type. Being able to set the appearance helps both when designing and checking, but also for assembly and product diagrams.
I just searched for said improvement request and couldn't find it. Given the huge number of upvotes here in this thread, I'd guess it would be good to publish the URL of the request so everybody who needs this functionality could support the ticket.
@Oliver_Couch
Thanks for posting this. It is in fact a nice example of a configurator! I like te idea of making a bolt or screw as needed in the design. I had to change the document units to metric, though, for it would else output the length of say an M8 screw in inches, but it apparently worked well after.
I'm a bit uncertain how to best integrate it in a workflow, though. It appears inappropriate to insert a copy each time I need a screw. On the other side, just using it to 'forge' screws, then inserting these as dumb objects, contradicts the concept. What do you think is the best method here?
Thank you for supplying this! It is a bit sad, though, that we need to create a custom configuration table to be able to change appearance, or even update the descriptions en masse, rather than being able to have an admin update the definitions directly in the standard content table. I've had the ability to do this in other CAD packages, and understand that customization makes standard not standard, but giving users the option of creating a company-specific standard from the pre-defined standard content would be helpful, and editing descriptions and colors in a table form is far superior to handling it on a case-by-case basis.
