Ortho Lines
nicola_malagnini
Member Posts: 35 EDU
hello.
i've used Ortho lines some times ago.
now i need to use it but it doesn't works. it's only my problem?
thanks
thanks
Also if there is a lot of entities (inferences) such as endpoints of other objects, if you get too close to those it will "wake them up" then your line attempts to find a suitable relation for those.
Finally, you should check your sketch plane. horizontal and vertical snaps are relative to the plane's x/y axis
press 'n" on your keyboard while in your sketch to view 'normal to' that should rotate your view normal to the x/y/z
no sorry, i'm speaking about Ortho lines Feature Script
- Select starting vertex
- Press "Add line"
- Drag manipulator
- Press "Add line" and set direction
- Drag manipulator
Not great I know but at least you can get the job done.https://forum.onshape.com/discussion/comment/73328#Comment_73328
RENDERCAD
