How to remove channel on cylinder
steve_pearson561
Member Posts: 7 ✭
in Drawings
There's got to be a simple answer to this but I just can't figure it out.
I need to cut a half-circle around the outside of a cylinder. I think I need to use the sweep command because I need to follow a path.
Here's an image of how I would like the channel to go:
This is very easy on a rectangle but can't get it to work on an extruded cylinder
Thank you for you help,
Steve
Steve
I have spent a fair amount of time trying to get your suggestion to work. Would it be possible for you to create a quick cylinder and cut a path similar to what I have so I can see all the details?
Sample document - https://cad.onshape.com/documents/a189da1fd14b9975f0ae4a9e/w/070045ac56b99446782c7a1b/e/5de29ad90232a7c9dfd8c862
Sorry to be a pest.. I pretty much have it working thanks to your example.
But in the end there is an odd piece of surface material there. I can't figure out what is causing it.
Thanks again for your help
Steve
My document here - https://cad.onshape.com/documents/154a8b4e0933f96b77f2759a/w/6cfc18e27f9b32fd6f7800da/e/15d77d143ee919f11ac228f9
Thanks for looking into my problem! I'm relatively new also but having so much fun with OnShape.
I didn't realize that the grey mate
I did try your suggestion making a circle but still get about the same results. Could you share your drawing so I can make sure I am doing the same?
I am now able to recreate what you did.
I'm not sure I understand why this is happening but now I see that if my sketch overlaps the wrap then I get those artifacts.
Thank you again for your help!!!
Steve
