How can we measure fillet dimension...?
Narayan_KNarayan_K Member Posts: 379 ✭✭✭
I am trying to measure fillet dimension of a model which is imported to Onshape.But i m not able to measure it.If i click on the fillet,it shows area in measurement tool.Is there any alternate way to measure fillet..?
    You can brute force it by cutting through the center of the revolve to create a section. You will then be able to highlight an edge.
    Alternately you can create a sketch through the center of the revolve and in the sketch use the 'use' tool to extract the fillet. you will then be able to measure this new edge, or dimension it.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    Yes it works...Thank you..
    @traveler_hauptman , nice work around method explained by you.
  • cd_dengcd_deng Member Posts: 1
    lougallo said:
    @Narayan_K We are working on adding that to measure.  Using edges is the option now.  Nice suggestion @traveler_hauptman
    I am interested in this fillet radius measurement as well, any progress?
    Thanks!
  • shaun_horganshaun_horgan Member Posts: 1
    I am also wondering how to add the dimension of a fillet.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,867
    If you use the "modify fillet" feature it will show you the current size of an imported model fillet - you can then change the value if you want.
