How to loft sketches that were created by patterns
fst
Member Posts: 79 ✭✭
Hi Onshape community,
have started to play around with Onshape - it's very promising!
As a first exercise (to find out whether Onshape can do what I need) I tried to create a conic rectangular shape with conic, rectangular holes. The number of holes should be parametric. I create both the conic body shape as well as the conic holes with lofts.
Haven't found out yet how I can create lots over all pairs of sketches that were created via two patterns. My "hack" was to manually define four lofts between four pairs of sub-faces of these patterns. This works - but only for up to the maximum pattern size I have created lofts for. And when reducing the pattern size the additional lofts are shown as red because their reference geometry is missing.
My description is probably not very intuitive. Please open the following example
https://cad.onshape.com/documents/86776a461ce86e88145657f8/w/2d27b485e436813cdaebe2bb/e/d97df18d012fa3b31f1ed490
and play with "num_pipes" in the variable table, change it first to numbers <= 4 and then to numbers > 4, then you will see what I mean. Would there be a more generic way to model this, so I don't need the explicit lofts anymore?
Thanks and all the best,
Ferdinand
Also, I think you may need to change your sharing options. I'm having a hard time making a copy of your document to fiddle with.
I think there are some instructions about sharing here: Forum Post Checklist **** READ THIS FIRST ****
https://cad.onshape.com/documents/e6501b337551dc9a7d5af58f/w/2d98f28f6045631459c40fa0/e/2aefa9a7cf5278a7e2c513b7
You actually picked a pretty tricky first exercise, but it seemed like a fun challenge. If you needed to make these a lot of these for some reason, it is possible write a whole custom feature that does all of it with a single command. You can also do it with just the native features, but the method is very Onshapey. See below.
I found a way to do it using some variables for math and a feature pattern to create a sort of "for loop" to iterate over. Note, I patterned surfaces, not sketches since it's more stable. I'm not going to cover everything I did since you can dig into my example document for that, but there are a number of important things with this method:
It seems that #i isn't used in your final solution anymore, right? So multiplying with i would probably be an alternative to putting the Transform step into the pattern?
haha, I didn't mean to rip you off 😬. I didn't see that you'd already done it since I queued up my reply last night, but didn't refresh the page to see new comments when I sent it this morning. I'm honestly just happy to have come up with something similar to Neil Cooke.
@ferdinand_strixner
You're right, I ended up making the #i obsolete without noticing. It's what I get for doing it at night.
I'm not sure why mine works without also patterning the Offset Surface feature, but Neil's doesn't like it. Since his is creating a new surface with each loop, I tried adding a Delete Part feature to it, and that works to get rid of all of the surfaces too.
