How can we measure fillet dimension...?
 Narayan_K
                    Member Posts: 379 ✭✭✭
Narayan_K
                    I am trying to measure fillet dimension of a model which is imported to
Onshape.But i m not able to measure it.If i click on the fillet,it shows
 area in measurement tool.Is there any alternate way to measure
fillet..?
             lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 @Narayan_K We are working on adding that to measure. Using edges is the option now. Nice suggestion @traveler_hauptmanLou Gallo / PD/UX - Support - Community / Onshape, Inc.5 @Narayan_K We are working on adding that to measure. Using edges is the option now. Nice suggestion @traveler_hauptmanLou Gallo / PD/UX - Support - Community / Onshape, Inc.5
Alternately you can create a sketch through the center of the revolve and in the sketch use the 'use' tool to extract the fillet. you will then be able to measure this new edge, or dimension it.
Thanks!
