Featurescript Request: Consolidate PCBAs
sam_hollandsam_holland Member Posts: 21 PRO
I have a workflow I use most of the time to take complex PCBAs from vendor sites and turn them into simple STEP files and I'd love to know if this is something I could automate with a featurescript. I don't have much experience but would absolutely love to learn if I had time
Many PCBAs I receive from vendors or clients come in as multiple assemblies with hundreds of parts. This becomes overwhelming quickly and takes a while to load.
Here is how I streamline these files:
1. Create a new part studio and upload the files
2. Open the top level assembly and create a new part in context
3. In this new part studio, copy parts in place using the transform tool
4. Use the composite parts tool to make a closed composite part
5. Export this part to a STEP and re-import into a new file
This workflow works really well when importing parts from mcmaster that are in assemblies but could be treated as dumb solids as well!
Is this something I could automate? Thanks in advance!
Sam
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Have you tried "Fix PCB"?
    Onshape | Product Development Platform
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    Looks like Neil's suggestion is the best way to go.
    However, if you still need to use your original method, a feasible feature idea could be to have a feature that copies all parts in the studio then composites them.
    Here is a feature that composites all parts: Composite Selected by @monroe_weber_shirk
    RENDERCAD
  • sam_hollandsam_holland Member Posts: 21 PRO
    Fix PCB only works occasionally for me, unfortunately.
