Part drawing that reflects assembly configuration?
in Drawings
Hi all,
Brand new to Onshape and struggling a little with configurations. I have a configurable assembly that is working great and will save us a lot of time doing custom designs. However, I can't figure out how to get drawings of the parts which make up the assembly. No matter how I do the drawing it just shows the part in its default configuration. The assembly has configurable dimensions, so it's not feasible to have a drawing of each possible dimension.
Is there a way to push configurations from the assembly level back through to the part file and/or drawing? Or any other workarounds other than manually changing every single part to match the assembly?
Appreciate any help.
Thanks,
Tom.
Thanks,
Tom.
I modeled the part here and then derived, and used for an assembly and drawings here. Hope that helps!
My assembly is made up of around 50 parts, all of which are sized to suit the overall size of the assembly, so it would be a HUGE time saver if all the drawings could update as per the assembly configuration rather than changing the configuration in 50+ parts or drawings.
