DXF Export has ? where there should be -
ConorConor Member Posts: 2
Using deviation tolerance, Instead of + on top and - on bottom in exported DXF file, there is + and ?. Hole callout was not used as holes were created using extrusion
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,925 image
    Hi @Conor - is that viewed in Onshape (exported then imported) or another software? If Onshape shows it like this can you please open a support ticket.
