Conic fillet advantage and working principle
viruviru Member, Developers Posts: 619 ✭✭✭✭
Onshape introduces a " conic fillet " capability in fillet which is useful in making complex shapes. The Conic fillet function lets us control the shape and size of each fillet to create smoother, more beautiful blends and fillets. This gives user to more choices and control over the look of your parts, including control of curvature. As a result, user can create smoother transitions between adjacent faces.
Conic fillet controlled by Rho value.User can give Rho value from 0 to 0.9999 for getting different types of conic curvature as shown in below image.
User can get Rho line by drawing perpendicular line on center of the line made of horizontal and vertical point of fillet distance. Rho line divide in 10 equal half for seeing working principle as shown in below image.
Working principle are in below video,
Now with the help of above information user can choose conic fillet option in fillet frequently.
With warm regards,
Viru
    @viru Great video and description of what the conic fillet does. Excellent
    @brucebartlett , thank you
    Just wrote to another discussion that I would like to see more info on 'checkbox features' to use them efficiently.
    Thanks @viru that is a great explanation.
    @3dcad ,thank you
    @viru - that is awesome, thank you :)
    Philip Thomas - Onshape
    Viru
    Thanks a lot for a beautiful exposition
    I guess it follows from fundamental trig that (at least when filleting a 90deg corner) the rho value corresponding to a circular arc will be one less than the square root of 2?
    ie  0.414ish ?
    3dexter3dexter Member Posts: 89 ✭✭✭
    +1
    I love to see also variable fillet.  :)
    jonathan_stedmanjonathan_stedman Member, Mentor Posts: 65 PRO
    Thanks for the great , simple explaination
    pete_yodispete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
    It would be nice to have @viru 's picture in the actual conic fillet dialogue...
    billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,022 PRO
    Thanks viru, great post.
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    @viru Very useful!
