How do i trim a portion of text?
rodger_ebert
Member Posts: 2 EDU
In meantime some generic ideas: good chance you can use direct editing tools or a standard tool like extrude or revolve with add selected.
You can also make a second sketch, and use the sketch with the text as references to make whatever geometric modifications you want - I added the rectangle at the top and used the trim command to make that shape:
