Mates for a L-shape path
johannes_becker
Member Posts: 8 ✭✭
in Drawings
Is there a way to to restrict the movement of parts in an assembly such that one part can move only along a L shape path? It is for a part that drops in from above and then slides horizontally. It would be like a slider mate vertically and at the end of the allowed path a slider mate horizontally.
Any hint will be appreciated
Johannes
is the master of this technique though, so he probably has better input. I mean, he animated solving a whole rubiks cube in Onshape which still blows my mind.
yea, that's pretty much how I would have done it
Further Suggestion:
If you have a lot of places where that path is needed, then you could make a configurable assembly that has the path and arrow, insert that assembly in every place you need to mate, and change its configuration to drive the path and shape. That way you can have a ready to go "L-Mate" that can be re-used while only drawing it once. At the same time the configurations set the 'limits". Then add a couple of mate connectors within it and it should be a rather decent work around. rather than matting a bunch of stuff in the main assembly on the fly.
