Auto Layout updated to V3.1: oriented parts!
Also fixed a small bug in the bin-packing algorithm, which in certain unfortunate combinations of parts could lead to part spacing constraints being violated.
Find it here: https://cad.onshape.com/documents/576e01dbe4b0cc2e7f46a55d/v/731e73ac0b7b1e4334f13106/e/b72c231628b5affea0873222
Arul Suresh
9
I'm currently working on a different joint script, but I'll add this to the list of improvements to make eventually.
Grain direction feature could be excellent. Maybe direction of grain could be determined by selecting edges of parts
example, a part that's 3/4"x3/4" will not fit in a piece of stock that's 3/4x3/4x120
I also wasn't able to figure out how to put a face down. I have a L shaped piece with the outside corner of the L rounded, and it assembles them into sticks in random orientations (based on where they started). When I hit the checkbox to pick a face for the orientation, it opened up a selection box, but then I was unable to select anything.
Not at all critical for me (purely cosmetic in this case), but letting you know of an issue I ran in to.
not quite the most minimal, but pretty small
That was what I was missing, I was trying to click on the faces of the parts as they were arranged. for something like the corner molding of this example, it's hard to know which direction it's going to end up being rotated (yes, that face will be down, but since it's not symmetrical when you flip it around 180 on the rod...)
so I was able to get one side down, now I'll go back and see if I can figure out which part is which to select a different face (and if it remains consistent or not over time and new parts)
https://cad.onshape.com/documents/f4173732c559f48d07645bdb/w/b7273cd4b0e02c93624d1f3f/e/aa9a35b9c41f56c8c476cba8
¿how do you export the resulting layout?, i can't find any way since they're not a 2D sketch so i can't export to flat DXF.
And since they're all individual parts i can't export all the top faces together in a single DXF either.
I need a 2D planar DXF of the resulting nest for manufacturing, not solid parts(i also can't find how to export all the parts together in a single file if i wanted that)
@guillermo_lovato create a drawing then insert the studio into a drawing with only the top view. Then you can export the drawing as DXF. While in the drawing, you can right click the view > Show/Hide edges. This will let you hide any edges you don't want to export.
interesting, i thought the export would constrain it to the page size of the drawing but appears to have exported everything at 1:1 as instructed. Tried it and it apparently worked
If you have multiple sheets, I usually insert a top view of the part studio and then do crop views to pick which cut layout gets exported on which drawing sheet.
Awesome Feature! just what i was looking for.
This is an awesome tool, but I did run across a case where the bin-packing fails. As you can see it's a fairly simple re-arrangement to get everything laid out on a single sheet.
This is what it generates
Hand adjusted
I've had similar simple cases (even simpler packs of pure rectangles) do the exact same thing,
This will happen sometimes depending on the input components, and I would argue isn't solvable in a FeatureScript context.
Since this feature is part of the total regeneration time of the part studio, this feature uses a First-Fit Decreasing packing algorithm to ensure deterministic operation and fast performance (in this case O(N log N) for N parts). Finding the optimal solution is NP-Hard and is therefore essentially not doable in any practical amount of time, and certainly not in a FeatureScript.
If optimal packing is critical for your application I'd suggest using one of the dedicated tools for that - I've used deepnest.io previously, which is open-source. Note that that is also not guaranteed to find an optimal solution, but it does keep trying options for as long as you have patience to let it improve.
is there an option for a user to set the nr of optimization attempts from 1 (fast) to e.g. 5 (optimal)?
I am building some moving shelves, and to avoid having a huge number of parts listed in the BOM, I've created a single shelf and then made duplicates of it in the assembly (with a linear pattern)
this works wonders for the BOM, but it breaks auto layout as it only sees a single shelf.
When I edit in context, there are 'ghost' shelves created that an be used for boolean actions, but auto layout does not appear to detect these, even when editing in context
https://cad.onshape.com/documents/d5a9827f1b61fec371e262ce/w/14dd034a6acd4e5e51af65fb/e/902b0119d1ee43890ff53924
before I went down this road, I ran into another problem with AL, if there are too many parts, it chokes (complains about a duplicate ID).
In my case I have a bookcase with 20 shelves, and 5 other parts. I then replicated to have 20 of these. When I got above 5ish AL failed to generate data
