Feature Script for stairs?
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 977 ✭✭✭✭✭
I was checking to see if there was a feature script out there that would help in the designing of stairs with landings and rails and follows OSHA standards?
Thank you for your replies and help in advance.
Bryan Lagrange
Twitter: @BryanLAGdesign
  • david_lang457david_lang457 Member Posts: 104 ✭✭✭
    I'd like to second this. Even without trying to have such a thing enforce standards, modeling a bunch of steps and extruding each step to the right height is a real pain (and then when the total changes and you need to adjust each step's rise...)
    what I did was to use the linear pattern to make the steps, manually made the landings, and then extruded each one (thick enough to overlap so the result could be one object). This seems like it's really crying out for a custom featurescript
    Is there any sort of marketplace where we can offer to reward people who produce such featurescripts?
    Is there any way to group featurescripts that are especially useful for a particular purpose (i.e. architectural related things)
    When you find a featurescript, is there any easy way to find a link to the discussion about it?
  • AustinPackardAustinPackard Member Posts: 7 ✭✭
    Thank you, @john_mcclary! I was also running into issues making a spiral staircase using a curve pattern off of a helix. The solution you detailed is a very clever way to quickly make and adjust this kind of feature.
