Can we edit previously used features in PartStudio by FeatureScript?
Is it possible to get list of features already made in part studio and edit their properties? For example I want to conditionally change beam size from Beam Feature. Can I do that?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Not with FeatureScript. You can get feature IDs of existing geometry but you can't edit its parameters. You can, however, use configurations to drive Beams, for example.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    Like Niel said, if you create a configured partstudio then you can create a shape library and plug in your values (or drive these values in realtime with variables)
    Here's mine that I shared Beams Library | Key Shafts (onshape.com)
  • dawid_michalskidawid_michalski Member Posts: 4
    Thanks Neil for quick response. What can I do with those IDs? And what option do I have for conditional configurations? I suppose I cannot edit configurations with FeatureScript? Maybe I don't need FS at all, and just don't yet know what configurations can achieve.
    John, also thank You. I'm trying to test your document, and it's kinda complicated :D Actually Beams is one example where you have possibility to use custom sketch. I was wondering what about miter all option, if it can be changed with FS, but understand now configurations can do that. Will learn them more.
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited January 2022
    In the GIF below, I edited the Beam feature.
    I changed it from a smaller beam to a bigger beam. Is this roughly the type of thing you’re asking about?
