Problem using Thicken on a simple surface
john_robinson568john_robinson568 Member Posts: 15
Hi All,
I've been using onshape for a few months now and have been getting the hang of it, but today I ran into a problem that has me stumped.
I have created a simple surface using a sweep. The sketches used to define the profile and path for the sweep are mostly constrained, but are simple with no sharp corners. If I try to use thicken on the surface in the inward direction, it fails. However if I mirror the surface, I can use thicken on the mirrored surface without any issues.
Could someone take a look at this really simple document and give me some hints please?
https://cad.onshape.com/documents/0824b97bad2a52c026499cde/w/4d7a37b5aa599b4ab4e6ef7d/e/1628b5a69b6ab5e46d8edaf8?renderMode=0&uiState=61fb6f29307158015c87649b
Many thanks, John
  • brooke_spreenbrooke_spreen Member, Developers Posts: 115 ✭✭✭
    Gave it a shot, but no luck. Strange that extra faces are being created on the underside of the successfully thickened part. Would guess this delves into the mysterious world of surface quality...
    Design Engineer | Anerdgy AG
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,869
    Can that point on the left be removed? Causing horrendous curvature
  • john_robinson568john_robinson568 Member Posts: 15
    Thanks guys for taking a look at this for me.
    You're on the money Neil, it was the point on the left causing the issue. I lowered it by 0.1mm and that fixed the issue. I am surprised by how sensitive it is, I have done a reasonable amount of surface modeling in onshape, and never encountered anything like this before. this one really had me stumped.
    I didn't realise you could visualise the curvature within a sketch, so thanks for the tip, that really helps a lot.
    Cheers John
  • EvanReeseEvanReese Member, Mentor Posts: 2,439 ✭✭✭✭✭
    If you can at all afford to remove the point instead of nudging it down it will make your model much more stable.
    Thanks Evan,
    I do need that point, but I will see if I can find another way. But what I don't understand is what is it about that particular point that makes it unstable? Is it that it is too close to the next point? Or is it because that point is "behind" the sweep profile sketch? Or something else altogether? Just trying to understand so that I don't make the same mistake again.
    Cheers John
  • S1monS1mon Member Posts: 3,358 PRO
    @john_robinson568
    If you turn on the "minimum radius" check box in the show curvature dialog, you will see a very small radius near that end. If the radius is smaller than the offset/thickness value, it's difficult to do the offset. Some CAD systems can approximate the result in that situation, but it's more of a challenge.
