Feature script "Beam" - feature library update
Since today I get this messge when using feature script "Beam" (graphic is in german):
"This workspace uses an old version of the feature library and must be updated before the Beam feature can be used".
A new Version for "Beam" is currently not available?
Thanks for your help.
Frank
Frank
romeograham Member, csevp Posts: 706 PRO
@frank_ring
It looks like you're not using the Official Beams featurescript - but someone's copy.
@NeilCooke above referenced the Official one is at V28.
You can install it from here: https://jps.onshape.com/documents/e15c2c668d138f01242d0c80/v/346d15aa4aa231b970b2fa9a/e/2d5660fc1012df9598f002510
Does anyone have any ideas?
Version should be original V28
https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/v/346d15aa4aa231b970b2fa9a/e/2d5660fc1012df9598f00251
I get the same problem, but with the frame Feature
I use OnShape since yesterday.
You can force a document version update by deleting and restoring a document.
The frame feature is based on the beam feature I believe.
