Creating holes that within a specified distance
brennan_natolibrennan_natoli Member Posts: 17 EDU
How can I use the linear pattern tool to create holes that are equal distance apart within a specified distance?
Fusion is great becuase it allows you to set the diameter of the hole, number of holes, and set the distance. From there it will create equally spaced holes within that specified distance.
Is this possible in Onshape?https://cad.onshape.com/documents/3e561bcbec745d87f86c88b5/w/8b7c173e0a59da9b0661d382/e/fe3275b286cfbdb82957412a?renderMode=0&uiState=623cb65365fb366a26fd66dc
I am trying to create this grid pattern.
