Circular Pattern of a Feature & Merge???
christopher_owens
Member Posts: 235 ✭✭
Hello! I created a 'Revolve-Solid-Add' (a "rib" for a domed feature) and then I wanted to create a "Circular Pattern" (8 instances) of that "rib". But, the "Add" solid merged with 'Part 1' and I could not pick it or 'Revolve 2' from the Features list to revolve & copy the rib!!! Sooo, I went back to the 'Revolve 2' and changed it from 'Add' to 'New' which made it 'Part 3'. Ok, so now I can make a 'Circular Pattern' of 'Part 3' with 8 instances which created 'Part 4' to 'Part 10'!! There is no 'Merge All Instances' with a 'Merge with All' or 'Merge Scope' selection. I figure I will have to create a 'Boolean'-'Union' to merge all together.
Optionserwin_1 Member Posts: 15 ✭✭Check the 'Face pattern' checkbox in the Circular pattern information window.
Then you can select al the faces of the rib to rotate.
Did a simple version here:
https://cad.onshape.com/documents/fe5099b8c2954423aa2a9d63/w/2b05d4fb23c24b6b887974c0
5 -
Optionsjakeramsley Member, Moderator, Onshape Employees, Developers Posts: 657christopher_owens said:@andrew_troup & @lougalloI noticed today doing a Circular Pattern-Add of a Part, that when the Part intersected itself, the parts Merged into one without selecting a Scope! Was this here before??? If the parts do not intersect (4 copies) the error is "Boolean failed...".Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
One thing to avoid in the more general case when exploring this workflow is any locale where two bodies touch only at a single edge, meaning the united body would be infinitely thin at that point. Solid modellers do not generally cope with "zero thickness geometry" like this.
Sometimes in such cases you have to use a 'thicken', towards the other body, before invoking a boolean union, if dealing with geometry which is not defined by graphic primitives like arcs and lines. If it is based on splines, there will need to be computational approximations, resulting in inevitable mismatches between nominally mating faces.
Test/recreate file image:
File that I noticed this: (Actually the Merge is what I ultimately wanted!)
If the parts do not intersect for "Add" then it shows error but still the operation is performed by forming new parts in the part list.It is not only happening for mirror or pattern,we can also find the same problem while extruding also.if we define a part for "merge with" while extrude operation and the part do not intersect with extrude then also the same case....
