How do you undo an appearance change to revert to the default?
monroe_weber_shirk
Member Posts: 103 EDU
I normally control appearance using FeatureScript. If I manually play with the color of a part, then the FeatureScript code that sets the appearance is overridden. How can I revert to the default color scheme so that the FeatureScript appearance changes are applied again?
EvanReese
Member, Mentor Posts: 2,694 PRO
If it's added to a face, not the part, then you need to open the appearances panel and delete the face appearances. Does that do what you need?
1
Also:
Is there an appearance panel other then the one reachable through right click?
