Sketchblocks
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
Is it possible to create a sketch I can reuse in different part studios? Like a drillingpattern for some standardparts.
Best regards
Best regards
Best regards,
Axel Kollmenter
Axel Kollmenter
mlaflecheCAD
Member, Onshape Employees, Developers Posts: 199
Yes @axel_kollmenter, the "Derive" feature in a part studio will let you choose sketches, surfaces and solids that you may want to reference from another part studio or from the part studio of another document. A common best practice here is to create a library of documents with the sketches you need that you can pull some of this standard data from. Read more here https://cad.onshape.com/help/Content/derived.htm?Highlight=derive
Regards,Mike LaFleche @mlaflecheCAD2 -
MichaelPascoe
Member Posts: 2,814 PRO
Here is an example of how to use Point derive with sketches, you will need to add it to your toolbar:
https://cad.onshape.com/documents/32cd3214ce848617bb5cf3cd/w/20b96bae9aa4c1952b1b417d/e/5549adaa9bcf43af25765434?renderMode=0&uiState=625ebefdedca45003961d68e
RENDERCAD
________________________________________________________________________2
Something I have found helpful is to use Offset surface, to create a surface of the closed regions of the sketch. Then when I derive the surface, I can easily transform it then reference it similarly to a sketch.
It is also possible to configure the sketch so that when you derive, you can choose how many holes you would like your template to have. Most inputs can be configured.
A great way to derive and transform all at once is with @Alex_Kempen's custom feature Point derive.
RENDERCAD
@mlaflecheCAD Now the sketch snapped automaticaly to the origin. Can I reposition it?
Axel Kollmenter
Edit: The way to move things in Onshape is with the Transform tool. It is best practice not to use this unless deriving parts.
Also, check out the Self Paced Courses in the Onshape learning center. They are fantastic.
RENDERCAD
https://cad.onshape.com/documents/5f75cccb3035075f70bd60af/w/b7ea4569428572eba8097166/e/63f65bed05229711683fe7aa
I want to use this sketch in different parts and want to reposition it.
Thanks
Axel Kollmenter
RENDERCAD
Axel Kollmenter
