How do you undo an appearance change to revert to the default?
I normally control appearance using FeatureScript. If I manually play with the color of a part, then the FeatureScript code that sets the appearance is overridden. How can I revert to the default color scheme so that the FeatureScript appearance changes are applied again?
  • EvanReeseEvanReese Member, Mentor Posts: 2,468 ✭✭✭✭✭
    If it's added to a face, not the part, then you need to open the appearances panel and delete the face appearances. Does that do what you need?
  • eric_pestyeric_pesty Member Posts: 2,275 PRO
    I think what you are looking for is the "reset all" (or something like this) at the bottom of the properties. However it's all or nothing so it will reset all of the properties...
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 99 EDU
    The reset button is grayed out even after I add an appearance to a face.
    Okay! That is sweet. Thank you!
  • Joel_VermeulenJoel_Vermeulen Member Posts: 3
    edited February 2024
    I still have problems to remove specific face appearances, as when I remove all the selected faces, the green accept tick mark turns gray and i cannot select 0 faces, to remove the change completely. clicking the red X just returns to the previous state.
    Also:
    Is there an appearance panel other then the one reachable through right click?
    @Joel_Vermeulen there’s an appearance panel on the right.
