Is there a way to put a "Stop" on a Screw Mate?? (Planer Mate?)
For instance when a bolt head seats on a washe, or two parts "Planer Mate" when screwed together. I used a Screw Mate and one part will continue to pass through the other when it should "bottom" and stop. Hmmm... I guess I could have a Planer Mate I suppress...
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
@christopher_owens You are looking for a limit mate.. We have not released one yet.
Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
You make a very interesting point. There will always be the need for a distance-specified limit mate, it seems to me...
Not least, because range of motion is generally established early in a mechanism design, whereas stop blocks tend to be added once the main elements have been fleshed out.
But I can see real advantages in rethinking the whole work flow in the light of the point you raise.
One promising possibility, I reckon, would be the ability (as an alternative to distance) to specify limits in terms of (say) mate connectors, which would become a visible but conceptual (and hence irreducibly simple) 'stop block'. Then when the real stop blocks get added, they could simply be mated to the pre-existing connectors.
I am completely new to design, as you can probably can tell! Started when I joined Onshape on July 16th...although I have an engineering past.
I like the sound of specifying limits in terms of mate connectors especialy as you can create your own mate connector positions on onshape. As a matter of interest can you create a mate connector position in space or does it have to be on existing defined geometry? I hope that makes sense.
At present, it can either be created on a model face or feature, then translated out into space, or created midway between faces/features, (and then optionally translated and/or reoriented to somewhere else in space)
I would personally like to also see the addition of construction axes, and coordinate systems, with the same user interface and toolset.
I assume from your above comment that some form of constraints for screws , slide etc are imminent. I do hope so as the inability to do so and the resulting part1 moving through part2 etc is extremely limiting for assembly design.
