SKETCH PLANE PROBLEM
vince_long
Member Posts: 9 ✭✭
I HAVE A SITUATION WHERE I WANT TO SELECT A FACE OF MY SOLID PART AS A SKETCH PLANE BUT MY SYSTEM WILL NOT LET ME SELECT CERTAIN FACES BUT IT DOES OTHERS.
https://cad.onshape.com/documents/0de04acb5bac92ca16796edf
can someone remind me how to upload the model so you all can see it?
Many thanks for the support.
You have a lot of sketches showing, the easy way to turn them all off is shift+p.
You could also use the ~key to select things underneath all your sketches.
