Arc with straight segments with loft
in Drawings
Hey,
i would like to draw a arc with straight segments. Here is the link: https://cad.onshape.com/documents/b09e2546059a1c9df86d6cf9/w/6a3d3c8a830438bf837eb0fe/e/db58689cd6160d6ab6fb56da
I made three sketches:
1x Loft, i choose the Loft tool and select all intersections. The segment are not straight, they are bend.
1x Loft with Guides, i draw two outside outlines at every segment and choose them as guidelines. This wont work... i dont know why ?!
5x Loft, i make every segment with one loft, this works the segments are straight.
Is it possible to to it with only 1x Loft and right guidelines ?
Why are my guidelines are wrong ?
Best regards
Kai
It's the same reason you can't have a spline that makes a corner.
If you want straight lines, then change your arcs to ellipses and maintain tangency across the boundary. Or, connect the lines with splines and maintain curvature across boundaries.
In the case of what you’re modeling, you could also use a sweep
https://cad.onshape.com/documents/997311fd7d7e6086696b41fb/w/5336c2235d0f4b15994bf969/e/4d8850db0ca83b8d9b5d1310
There’s two different parts studios in the doc
