Sketch Scale solution
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
Hello,
I saw that back in 2020 the function to scale a sketch was implemented to onshape.
How does this work? I have a undefined sketch with a width of 240mm and want to scale it up to 320mm (all other lines should scale proportional)
( https://forum.onshape.com/discussion/8976/sketch-scale )
Best regards,
Axel Kollmenter
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 974 ✭✭✭✭✭
    You could use the transform command and scale it to the size you need. Just click on the triangle and enter the scale value.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • romeograhamromeograham Member, csevp Posts: 740 PRO
    @Axel_Kollmenter
    If the sketch is has ONLY 1 DIMENSION, it will scale the entire sketch proportionally. You'll need to watch internal and external constraints that might prevent it from scaling.
    This way you can make a sketch have the correct aspect ratio etc...then add a single dimension to scale the whole thing.
    This also works when you place a DXF sketch into a sketch - works really well for imported wordmarks etc.
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    In my case I  copied the contur of an imported part (piktogram); deleted the importet part and deleted all external references. In This case I cant scale the sketch that way. I´ll make a seperate similar document to share it with you.
    Best regards,
    Axel Kollmenter
    Bryan Lagrange
    Aaah thats what Im looking for. Thank you!
    Best regards,
    Axel Kollmenter
