download high-res Onshape official icons
EvanReeseEvanReese Member, Mentor Posts: 2,693 PRO
I'm looking for a way to download full-res versions of the icons used in the UI, everything from the folder icon to the extrude feature icon. I'm building out a best practices document for our internal use and would like to incorporate the same icons that everyone is used to seeing in Onshape.
Another reason I'd like to see them larger is to imitate the style for my own custom feature icons.
I know for many of them I can zoom in and screenshot, but I'm wondering if there's an easier/better way to get them that's less labor-intensive.
    @Evan_Reese
    All the Part Studio icons, etc are stored in a file called icons.min.svg. You can then view the source of the page and just copy the region (including <symbol> tags) pertaining to the specific icon that you want. You can then replace the <symbol> tags with <svg> tags, keeping the viewbox attribute on the opening tag and adding a width="200px" to the first tag to enlarge the icon.
