I
alison_gray769alison_gray769 Member Posts: 16
 I am a recent user of Onshape  does the public version offer custom detail drawings where each element of an
 assembly can be labeled?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Yes
  • Hans_Leirvik_1Hans_Leirvik_1 Member Posts: 40 ✭✭
    Just create a drawing View for each part or assembly
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    I believe you will only be limited to the default part properties as a free user. If you go pro or higher, then you will gain access to custom property names
