Fillet Width Measurement Option Fails Randomly
VinceHaley_SkillCoach
                    Member Posts: 11 ✭✭
            Quick question, I'm having way too many instances where the "width" option on the fillet tool fails to run. In most scenarios I consider the geometry to be straightforward. In the example below I tried adding the fillet to both solid and surface geometry. If I change the measurement option to radius the fillet will work on the example geometry.
Are there any known issues are limitations?
Thanks in advance,
Vince Haley
SkillCoach
Whenever a fillet fails, try a much smaller number and sneak up on the failure so that you understand what's happening.
Creative and Technical Skill Development Coach
Design Inspiration
LinkedIn Bio
