New Custom Feature: Simplify
NeilCooke
Moderator, Onshape Employees Posts: 6,007
A common requirement when sharing CAD data is to simplify it by removing internal details and intellectual property. This feature, in combination with in-context modelling, creates a simplified representation of an assembly or part. Please try it out and if you find any problems or have any examples where it doesn't work, let me know. Enjoy!
https://cad.onshape.com/documents/3f84343841cb6d7fead072c8
Video on how to use:
23
Axel Kollmenter
Seems like the document is view only.
RENDERCAD
+1 really cool
Weldments are made from assemblies but when completed are one part that can be modified. ie. machine the top off to flatten and remove distortion. Drill a few holes and what not.
Would apply to castings also.
https://cad.onshape.com/documents/4d54c097f06df74ad7d2c098/w/95756f907817bad134521b92/e/4e1b749797af37864c6f3b15
Any non-manifold error is where two parts are touching at an infinitely small edge or vertex, so you may need to modify or move/remove one of the parts (full disclosure - I cheated in the video - the shaft seal on the gear pump is tangent to the shaft, creating non-manifold geometry, so I edited the part by a few microns first).
Why is this so hard to make work?
