Workbench background issue
Moon
Member Posts: 6 ✭
Hi,
I am new in onshape and trying to get introduced with the paltform.
Like other discussion threads, I am also facing the issue "Dark workbench background".
I tried with edge and also chrome but did not resolve the problem?
Can anyone help me to bring it into 'light'?
1
Moon
Member Posts: 6 ✭
Hi everyone !
I got the problem solved. This works for me by the way below:
First, I checked if my graphics card is blacklisted or not, after ensuring that it is not,
I checked if my browser supports WebGL by going through this link https://get.webgl.org/
Then, I went to chrome://settings and ensured that hardware acceleration is turned on.
Afterwards, chrome://flags and search for my WebGL version but didn't find any.
Finally, I enabled the Override software rendering list and relaunched chrome and found my workbench light.
However, this is not the recommended way as mentioned in different online tech articles.
I am not sure what problems I going to face for this change! After all, it works.2
Axel Kollmenter
chadstoltzfus@premiercb.com
Are your sketch lines still blue and black? or does they change to another color too?
Axel Kollmenter
Should I try some other browsers? Specifically, is this problem related to the browser configuration or my PC's hardware configuration?
can you show a screen shot of your results from
Compatibility check (onshape.com)
We're looking to see if all the check marks are green and your GL renderer is what you are expecting. (on a laptop it may be your integrated graphics like Intel, if you have the option for a discrete card you may have to set your browser up to always use it. In my case you can see it is set up to use the nVidia card)
Part/face colors remain intact as well. Of course, you could run into some visibility issues if you color your parts black/charcoal.
Is this alright? Should I configure anything?
The overall performance looks very low (less than 1% of what top machines are doing these days). There may be some browser settings which can help. Click on the "Graphics Performance Recommendations" link and follow the instructions.
Aah thanks. I don't think that's good. Then I have to look very carefully every time where my lines are. I think with the bright background you save some time.
Axel Kollmenter
